Group: DynoMotion Message: 1425 From: bradodarb Date: 7/5/2011
Subject: Run python script from interpreter
Hello
I have seen in the sources where you can load and run a c program from a g-code file.
I would like to come up with some sort of way to keep the original functionality, but also have the ability to fire off an Iron Python script as well.
Do you have any advice on the best way to intercept calls like this?
-Brad Murry
Group: DynoMotion Message: 1427 From: Tom Kerekes Date: 7/5/2011
Subject: Re: Run python script from interpreter
Hi Brad,
I assume you mean to run on the PC side rather than the DSP side.
Besides specifying .c files to be compiled, downloaded, and executed there is an option for an MCode or User Button to execute a Windows Executable.  Search for:
case M_Action_Program_PC:
However I would think the problem would be that the Python would run as a separate process and wouldn't have access to any of the variables in the libraries or Interpreter or your application.  Maybe I don't understand your intent.
--- On Tue, 7/5/11, bradodarb <bradodarb@...> wrote:
Subject: [DynoMotion] Run python script from interpreter
Date: Tuesday, July 5, 2011, 8:50 AM
Hello
-Brad Murry
Group: DynoMotion Message: 1428 From: bradodarb Date: 7/5/2011
I now recall seeing the load file and Mcode as well.
I will need to look further into the Mcodes.
In Iron Python, scripts run int the DLR(Dynamic Language Runtime, but are compatible with CLR(Common Language Runtime - which is what .net languages compile to) objects.
I can generate a dynamic runtime and add whichever variables I wish, including objects in my application(especially the c# wrappers I am creating for your DynoMotion devices).
So basically how the framework is used at my work and how I wish to incorporate the DynoMotion hardware is:
C/C++ :: dlls for device access
c# :: dlls for wrapping the device in abstracted objects
c#/WPF :: application for great GUI
Iron Python :: for controlling the actual behavior of the c#/C/C++ objects.
The python scripting is great to use on things like confiuring the UI so it can display different interfaces, options, etc.. at runtime. I also use the scripting for things like a tool changer or even to define what happens when an operator presses cycle start.
I realize most if not all what I want to acomplish could be handed in your c scripts, but to maintain compatability with my existing framework and to enable the manipulation of CLR objects I need to use Iron Python.
I am not sure loading from file will be as performant as I need it to be, I typically cache most scripts in a pre-compiled run-time for speedy execution.
It would be great if there was a User Block Callback available in the interpreter.
Brad Murry
> Hi Brad,
> Hello
> -Brad Murry
Group: DynoMotion Message: 1431 From: zenhacker@ymail.com Date: 7/5/2011
I have been taking note of the recent rumblings on the C#/Dynomotion front, it has me excited.
I must admit, I left C++ hat somewhere back in the early 90's with Borland Turbo C++ 3.0 and DOS, and just never succeeded in finding it again when moving into Windows programming and trying to do AFX/MFC in Visual C++. I dabbled some with VB6, but didn't really fall in love with programming windows again, until .NET 2.0 came out.
Seeing a Managed Framework come to fruition that harnesses the power of Dynomotion is something I would welcome with open arms (is it too much to hope that access to the RS274 Interpreter, and trajectory planner make the managed transition too? I hope not). Forms (WPF or WinForms) in .NET are both very easy to layout dynamically relative to display resolution, and even built programmatically at runtime based on demand (relative to my intermediate skill set at least). WPF of course opens the door to create some very spectacular looking UI's. Adding Iron Python for scripting support would be icing on the proverbial cake (since you are looking at the DLR, Ruby, or any other language with a DLR Implementation could be supported). But I digress.
Brad, I noticed the earlier post to your C# Wrapper but I have not had a chance to download and test anything yet. Is it your intention to create a Wrapper/Framework for public consumption (framework meaning the WPF/DLR aspects you discussed here), or is the wrapper portion all that is planned currently?
Best Regards,
Patrick Hall
> Tom,
> Thanks,
> Brad Murry
> > Hi Brad,
> > --- On Tue, 7/5/11, bradodarb <bradodarb@> wrote:
> > Hello
> > -Brad Murry
Group: DynoMotion Message: 1432 From: bradodarb Date: 7/5/2011
I am happy to see that there is a good chance the efforts to create a managed framework that is capable of integrating with DynoMotion devices will be useful to others.
Hopefully the libraries will help move some more silicone for DynoMotion and keep fueling their hardware innovation goodness.
The aforementioned feature set will become available in its entirety, as it is already a product I developed for my current employer. I am taking the oppurtunity to refactor it while I am integrating the Dyno API's plus I am removing some proprietary API's that may not be useful to people outside of my employer's customer base.
Alas, the nitty gritty must be done first and that is to get a stable and full-featured set of wrappers to build the rest on top of.
Keep an eye on the SourceForge site to see progress, and I will post important updates here as well.
Anyone who may wish to use these libraries, please feel free to post feedback.
Cheers,
Brad Murry
> Best Regards,
> Patrick Hall
> > Tom,
> > Thanks,
> > Brad Murry
> > > Hi Brad,
> > > Regards
> > > Hello
> > > -Brad Murry
Group: DynoMotion Message: 1433 From: Lee Studley Date: 7/5/2011
Hi, took the other path :-)
I haven't embraced C# and really have tried to distance myself from Microsoft's iron grip on how
they think things should be done( by you in their opinion ). They seem to want to control how you think.
I have have always  liked C++ since the turbo C days. It was a niceadvancement/alternative to Pascal object oriented
development. Visual basic gives me the heaves. I have recently converted many of my programs to JAVA as speed is
not much of an issue there today. And I can run/port to linux with minimum effort.
I'm not just a novice speaking here: I professionally wrote C++ gui's for intersil/Sicom and others for control and evaluation of asic features.
This included custom controls with subclassing etc.
I now like JAVA, C++ w/ STL and Python as my tools of choice.
just my 2 pennies.
Best Regards,
Patrick Hall
Group: DynoMotion Message: 1434 From: bradodarb Date: 7/6/2011
Lee,
It's pretty cool that mono exists and I can run c# on Linux boxes these days with little to no additional effort. I can even port gorgeous WPF calm based vector drawn GUI's over with moonlight.
It truly is an incredible time to be a programmer.
I also think corporations are pretty much like politicians, they're all necessary evils. I'm not sure oracle is any more or less evil than Microsoft.....
I reckon we can agree that garbage collected languages with massive libraries are great to make software with as they let us focus more on the application and less on the implementation; python rules!(Iron Python is recorded as the most performant, BTW) and Dynomotion hardware is awesome enough to spend time in the wee hours on this group.
Anyhow, I think maybe this discussion has drifted outside the realm of this forum.... so -
It would be cool to see a java wrapper implementation as well.
How hard would it be to wrestle the DynoMotion codebase away from MS(MFC, etc..) I wonder?
-Brad Murry
> minimum effort.
> just my 2 pennies.
> > Best Regards,
> > Patrick Hall
Group: DynoMotion Message: 1435 From: bradodarb Date: 7/6/2011
Any chance of seeing a User Block Callback in an upcoming build?
Or if you have another suggestion that does not involvef changing you code? I do not want to implement it myself(and do so every subsequent update)
-Brad Murry
> Tom,
> Thanks,
> Brad Murry
> > Hi Brad,
> > Hello
> > -Brad Murry
Group: DynoMotion Message: 1436 From: Tom Kerekes Date: 7/6/2011
Hi Brad,
Its not clear to me what you mean.  A callback from a GCode Block?  As an M Code?  What/when would register the call back?
If you implement the change (and there is no major disadvantage for others) we will incorporate it in future releases.
--- On Wed, 7/6/11, bradodarb <bradodarb@...> wrote:
Subject: [DynoMotion] Re: Run python script from interpreter
Date: Wednesday, July 6, 2011, 10:21 AM
-Brad Murry
> Tom,
> Thanks,
> Brad Murry
> > Hi Brad,
> > Hello
> > -Brad Murry
Group: DynoMotion Message: 1437 From: bradodarb Date: 7/6/2011
Sounds great Tom,
This is what I am thinking:
adding a string flag for user defined block:
GO X0.0 Y1.0
M6 T2
[UserBlockFlag] UserMessage
G1........
Maybe the flag could be some thing like _UB
GO X0.0 Y1.0
M6 T2
_UB UserMessage
G1........
Then an callback handler similar to
G_STATUS_CALLBACK or G_COMPLETE_CALLBACK
G_USERBLOCK_CALLBACK could be added and pass the user message to a function pointer where I can handle it in a delegate on the c# side.
In my case, the UserMessage would be a script name and I would fire it off once the message was received.
.....While thinking this through it would also be excellent to have a wait parameter on the callback.
Just do the callback
_UB 0 UserMessage
do the callback and dwell until resume is called
_UB 1 UserMessage
Make sense? Any pitfalls to watch out for or pointers in the right direction is appreciated.
Thanks for your time,
Brad Murry
> Hi Brad,
> -Brad Murry
> > Tom,
> > Thanks,
> > Brad Murry
> > > Hi Brad,
> > > Regards
> > > Hello
> > > -Brad Murry
Group: DynoMotion Message: 1438 From: Lee Studley Date: 7/6/2011
Hi Brad,
I meant no offense whatsoever :-) Not heard of "mono" will check into it. C# probably has more to offer
than I realize: just my ignorance of getting immersed in it showing.
I think this topic is ok for the forum: it shows areas of interest
for Tom K to support is the desire is there.
I use CodeProject.com a lot and they raz me some on my Java preferences, but whats nice is Java projects you
had awhile back run perfectly when you revisit them years later.
I took MFC training in 1995 when it was the "future", and then peeked into JAVA as it was touted in all the microsoft
documentation/help( as new classes ) as the new pathway to success, then the legalities MS/SUN
occurred, then .net and C# where born pretty much due to that falling out.
http://en.wikipedia.org/wiki/Java_%28programming_language%29
I will do a JAVA interface to access the DynoMotion code soon I hope. I was on sabbatical from work, but they called me back. Hoping to get
a few more weeks somehow to play as I just bought the KFLOP and KAnalog to add to my BP seriesII-4J-4hp monstrocity.
Glad we have members like you with code experiences and well written points to keep ( my ) mind flexible!
Sincerely to you all :-)  and please call me on being opinionated if I come across that way.
Lee Studley
On 7/6/2011 12:07 AM, bradodarb wrote:
Lee,
-Brad Murry
> minimum effort.
> just my 2 pennies.
> > Best Regards,
> > Patrick Hall
Group: DynoMotion Message: 1439 From: bradodarb Date: 7/6/2011
Lee,
None taken!
I was just balancing the PH ;)
I agree, the more people that can access the Dynomotion devices the better off we all are, and that means that providing more ways(ie. languages) people can interact with the hardware with is a worthy effort.
Java is a great language and I use it on web services from time to time. Other than the IDE it almost feels just like working in c#. Who can really fault any C derived language anyhow?
Good luck with your Mill, sounds like something I wish I had space for.
-Brad Murry
> Hi Brad,
> Lee Studley
> > Lee,
> > Microsoft.....
> > this forum.... so -
> > -Brad Murry
> > converted
> > > minimum effort.
> > features.
> > > just my 2 pennies.
> > AFX/MFC in
> > relative to
> > had
> > all
> > > > Best Regards,
> > > > Patrick Hall
Group: DynoMotion Message: 1443 From: Tom Kerekes Date: 7/6/2011
Hi Brad,
There already is a kludge method of throwing up Windows message boxes and sending Console Script commands to KFLOP using a special form of a G Code comment.  I'm thinking it would be easier and more consistant to follow that same line.
(MSG,Press OK to continue)
and
(CMD,MoveRel0=100)
we could add
(USR,DoFunction1)
I don't see why we need the wait/resume option because it would be up to your callback to either return immediately or wait.
There might be a need for an option to re-sync the interpreter.  We have this option with M Codes that launch C programs in KFLOP.  After the Program completes if the program moved the axes for example it is usually required to re-sync the interpreter state to the axes states.
Date: Wednesday, July 6, 2011, 10:51 AM
Sounds great Tom,
GO X0.0 Y1.0
M6 T2
G1........
GO X0.0 Y1.0
M6 T2
_UB UserMessage
G1........
_UB 0 UserMessage
_UB 1 UserMessage
Brad Murry
> Hi Brad,
> -Brad Murry
> > Tom,
> > Thanks,
> > Brad Murry
> > > Hi Brad,
> > > Regards
> > > Hello
> > > -Brad Murry
Group: DynoMotion Message: 1444 From: bradodarb Date: 7/6/2011
Hello Tom,
 That sounds like an ideal solution.
  I guess I had assumed the callback would be sent on a separate thread than the interpreter.  If the callback is blocking,  then yeah no need for the wait/resume.
  Syncing the interpreter sounds like the way to go.  I had considered that I might need to re-position the axes to their callback positions after the script fired but I think just letting the interpreter know where the current position is would suffice for most scenarios.
When you said:
 we could add
 (USR,DoFunction1)
Does this mean you will be implementing this new funtion?  If so do do you think it could be accomplished within the next 2-3 weeks?
This is when I plan to have the RS274 wrapper implemented and ready for beta.
Brad Murry
> Hi Brad,
> and
> (CMD,MoveRel0=100)
> we could add
> (USR,DoFunction1)
> --- On Wed, 7/6/11, bradodarb bradodarb@... wrote:
> From: bradodarb bradodarb@...
> Sounds great Tom,
> GO X0.0 Y1.0
> M6 T2
> G1........
> GO X0.0 Y1.0
> M6 T2
> _UB UserMessage
> G1........
> _UB 0 UserMessage
> _UB 1 UserMessage
> Brad Murry
> --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote:
> > Hi Brad,
> > -Brad Murry
> > > Tom,
> > > Thanks,
> > > Brad Murry
> > > > Hi Brad,
> > > > Regards
> > > > TK
> > > > Hello
> > > > -Brad Murry
Group: DynoMotion Message: 1450 From: Tom Kerekes Date: 7/7/2011
Hi Brad,
I added the GCode User Callback feature and it basically seems to work.  See files at:
There are 3 changed source files and the compiled DLL.
There is also a modified SimpleGCode example that I used to test and some GCode that makes the Callback.
Date: Wednesday, July 6, 2011, 7:01 PM
Hello Tom,
When you said:
 we could add
 (USR,DoFunction1)
Brad Murry
> Hi Brad,
> and
> (CMD,MoveRel0=100)
> we could add
> (USR,DoFunction1)
> Sounds great Tom,
> GO X0.0 Y1.0
> M6 T2
> G1........
> GO X0.0 Y1.0
> M6 T2
> _UB UserMessage
> G1........
> _UB 0 UserMessage
> _UB 1 UserMessage
> Brad Murry
> > Hi Brad,
> > -Brad Murry
> > > Tom,
> > > Thanks,
> > > Brad Murry
> > > > Hi Brad,
> > > > Regards
> > > > TK
> > > > Hello
> > > > -Brad Murry
Group: DynoMotion Message: 1455 From: bradodarb Date: 7/8/2011
Wow, now thats fast progress!
Thanks Tom, can't wait to try that out.
-Brad Murry
> Hi Brad,
> http://www.dynomotion.com/Software/UserCallBack/
> Hello Tom,
> When you said:
>  we could add
>  (USR,DoFunction1)
> Thanks,
> Brad Murry
> > Hi Brad,
> > and
> > (CMD,MoveRel0=100)
> > we could add
> > (USR,DoFunction1)
> > Sounds great Tom,
> > GO X0.0 Y1.0
> > M6 T2
> > G1........
> > GO X0.0 Y1.0
> > M6 T2
> > _UB UserMessage
> > G1........
> > _UB 0 UserMessage
> > _UB 1 UserMessage
> > Brad Murry
> > > Hi Brad,
> > > Regards
> > > -Brad Murry
> > > > Tom,
> > > > Thanks,
> > > > Brad Murry
> > > > > Hi Brad,
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > Besides specifying .c files to be compiled, downloaded, and executed there is an option for an MCode or User Button to execute a Windows Executable.ÃÆ'‚  Search for:
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > However I would think the problem would be that the Python would run as a separate process and wouldn't have access to any of the variables in the libraries or Interpreter or your application.ÃÆ'‚  Maybe I don't understand your intent.
> > > > > ÃÆ'‚
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > Hello
> > > > > -Brad Murry
